If you are trying to get ABC on WVNY in Burlington, it's on real channel 13, and you'll probably need an antenna with Hi-VHF capability. If you have rabbit ears or any indoor antenna, you might try it. Hot spots often work with simple antennas and just confirming that a signal is present is a step forward. Fox on WFFF, also in Burlington is on real channel 43 and in the same direction as NBC and CBS. I would try raising or lowering the existing antenna instead of moving it. I suggest you try to find a way to tune the TV to real channel 43 and watch or have someone else watch the TV during the adjustment.
