Old 5-Aug-2014, 7:40 AM   #2
A Simple Reception Situation.
A antenna rotator is not required.
Detroit and Toledo , Digital Broadcast Tv Stations/Channels will be received.
Above the Peak of the Roof install a HD1200 All Channel Antenna in such a manner that the , attic , roof , building , are not , obstructing , impeding , blocking , reception in the directions of , South East , South , North East , West.
http://www.antennacraft.net.
HD1200 All Channel Antenna aimed at about 45 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
As always , the antenna aim can be adjusted and the antenna location can be adjusted for the best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a ,
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html . Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html . Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
Trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and obstructions in the directions of reception including your own , attic , roof , building.
Absorbing and Blocking Reception.
For Reliable Reception install the HD1200 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building .
Last edited by teleview; 10-Aug-2014 at 9:39 AM. Reason: Clarify information and typos.
