Old 4-Aug-2014, 10:33 PM   #4
http://www.hollandelectronics.com.
Has a Flat Coax , window , door , jumper that is used to get the signal from the antenna outside to the Tv inside.
Model Number , 144823 .
The flat coax is built strong.
However Be Nice to the Flat coax , Do Not Slam windows and doors on the coax.
However Be Nice to the Flat coax , Do Not Force Windows and Doors too the point that flat coax is damaged and does not work.
Put some thought in to how the flat coax is fitting into window or door.
And some windows and doors fit So Tight that the window or door may not close all the way , with the flat coax in place.
Also know this ,
Almost Always when one of those small satellite dishes is installed outside the building , a hole is drilled through the wall of a condo or apartment to connect the satellite dish outside to the receiver inside.
So with that information , you can also drill a hole.
Last edited by teleview; 5-Aug-2014 at 12:58 AM. Reason: Clarify information and typos.
