Old 4-Aug-2014, 9:46 PM   #6
Yes is Ok to Test Reception the Tv stations/channels , no mater how weak the signal strengths are.
To that end , here are some , antennas , amplifiers , antenna mounts.
Antenna System #1.
It looks like ,
http://www.warenelectronics.com . Has the Winegard HD5030 , VHF channels 2 thru 6 antenna.
http://www.warenelectronics.com/antennas/HD5030.htm.
install a , http://www.antennacraft.net.
10G201 preamplifier.
Aim the the HD5030 antenna at about 349 degree magnetic compass direction.
For reception of ,
WBKP , Real VHF low band channel 5 , ABC and CW.
WBKP is very strong signal strength and will be received through the back angle of the antenna.
CKRP-DT , Real VHF low band channel 2 , CBC.
CHFD-DT , Real VHF low band channel 4 , GTN.
CICO-DT , Real VHF High band channel 9 TVO.
Antenna system #2.
Antennas Direct , DB8e , current UHF channels 14 thru 51.
http://www.amazon.com.
Install a , http://www.kitztech.com.
KT-200-COAX Tv , Antenna Booster , Remote Power-CoaxFed.
Aim the , DB8e antenna at about , 154 degree magnetic compass direction.
To Test for reception of ,
WLUC-TV , Real UHF band channel 35 , NBC and FOX and America One.
Antenna System #3.
HBU55 , VHF high band channels 7 thru 13 antenna aimed at about 153 degree magnetic compass direction.
Install a ,
Aim the HBU55 antenna at about , 153 degree magnetic compass direction.
For reception of WNMU-DT , Real VHF high band channel 13.
Here is how to aim antennas ,
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
As always , the antenna aim and location can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's will also have a Signal Quality Meter.
When the signal strength is strong enough for reliable , then Signal Quality becomes more important then more signal strength.
The antenna systems are All Separate antenna systems and are not connected together.
Separate Coaxes go to the Tv.
At the Tv location.
Separate Digital Tuner/Tuner Recorders are connected to the Separate antenna systems.
http://www.epvision.com.
Here are some Tall/High antenna mounts.
http://www.ronard.com/712.html
Above the Peak of the Roof install the , ronard(712-50-10) , 10 foot tripod antenna mount.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Here are , Free Standing , No Guy wires , Light Weight Aluminum , Lay over Towers.
http://www.palcoelectronics.com/pe300.aspx
Last edited by teleview; 5-Aug-2014 at 1:15 AM. Reason: Clarify information and typos.
