Old 4-Aug-2014, 3:16 AM   #4
For Improved reception of the , USA and Canada , Digital Broadcast Tv Stations/Channels.
Install a , Antennas Direct , DB8e , current UHF channels 14 thru 51 antenna.
Aim 1 panel at about , 227 degree magnetic compass direction.
Aim the other panel at about , 190 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
As always , the antenna aim direction and antenna location can be adjusted for the best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv 's also have a Signal Quality Meter.
For improved reception of.
WVNY-DT , Real VHF high band channel 13 , ABC.
Install a.
http://www.antennacraft.net.
Y10-7-13 VHF high band antenna for reception of channels 7 thru 13.
Aim the Y10-7-13 antenna at about 180 degree magnetic compass direction.
Install the Y10-7-13 antenna about 3 feet below the DB8e antenna on the same antenna mast/pipe.
The CM7777 is Too Strong a Amplifier for reception at your reception location.
Remove All Parts of the CM7777 preamplifier , Remove the Preamp Unit , Remove the Power Supply / Power Injector .
Install a.
10G221 preamplifier.
Connect the DB8e , UHF antenna to the , UHF connection of the 10G221 preamp.
Connect the Y10-7-13 VHF antenna to the VHF connection of the 10G221 preamp.
Here are some and not all Above The Peak of the Roof antenna mounts.
http://www.ronard.com/909911.html. Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) or ronard(2218) or ronard(2224) .
Home Depot has , 10 foot 3 inch length , 1 and 1/4 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe .
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The directions of reception at your location are , South , South West , West.
Last edited by teleview; 4-Aug-2014 at 9:05 AM. Reason: Clarify information and typos.
