Old 4-Aug-2014, 2:05 AM   #2
Outside on the East Balcony , install a.
http://www.antennacraft.net.
HBU11K antenna aimed to the North North East the best that the antenna will
aim the the North North East with out aiming the antenna into the side of the
building.
Or
Can install a.
HD-1080 antenna.
and
J type pipe mount , Winegard DS2000.
Here is how to aim antennas ,
Here is the Federal Antenna Law that says Yes you can install the Tv antenna
outside on the balcony.
http://www.fcc.gov/mb/facts/otard.html.
The Tv Stations Reception is Strong Signal Strength at Your Reception Location.
A antenna system amplifier is Not required.
Digital Tv Tuners can save - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 5-Aug-2014 at 1:04 AM. Reason: Clarify information and typos.
