Old 3-Aug-2014, 11:07 PM   #38
Stereocraig
Originally Posted by corvairbob View Post
i have a uhf only antenna it has only one set of elements that actual gather the signal the rest are just for looks i guess when i used that box alone i got the same amount of signal. how may elements on the 91xg are connected to the coax? plus the vhf signal it leaves out correct? i went to the solid signal site and asked them for help on picking out an antenna lets see how much money they want me to spend.
Only two elements are hooked to the coax, unless that's considered to be the odd one.
The ones in front, are directors and are actually isolated from anything else.
The rear screen is a reflector and is common to the mast/ boom.
Even the coax shield, is isolated from the mast/ boom.
I believe the 91 refers to the total number of elements.
