Old 3-Aug-2014, 6:38 PM   #25
Billiam
Originally Posted by sd121 View Post
Yes I can and would get help with the mounting. I can run/mount a pole along side the house and put the antenna on that. This would could give the same or more height (2 story house) and greater distance from the tree line if that would be helpful.
I did that at my former house. I used four two foot long 2 by 4's bolted to the studs on the side of the house and then mounted mounting brackets into each 2 by 4. At the base I used three cinder blocks filled with cement that had the bottom mast secured at the ground. First, I centered the mast, then poured the cement and then let it sit for a while until it started to solidify. Then I carefully pulled the mast out so as to not disturb the cement and cleaned it off. After it had dried I was able to slip in the mast and slip it out with ease when needed.
Use a couple of flat blocks as a base to put the cinder blocks on. That way you won't have a pile of cement sitting on the ground and also a better base to stabilize the mast.
