Nope. A few degrees with this antenna will not matter except possibly with KICU and that is if you can even get it in. For the rest of them it will not be an issue.
I recommend the following rotor. I own it and it is reliable and can handle the HBU 44 with ease. I had a HBU 55 on it (larger than the HBU 44) and the rotor didn't need to be reset very often unless high winds were an issue. Resetting the rotor is easy and done from inside the home.
