Yes, a pre amp can create interference from strong signals nearby. In this case I would only recommend it if you have to watch KICU but that does not seem to be a requirement. If the trees were not a problem then I would think it would come in without a pre amp since I've been able to get signals that weak or weaker on UHF without a pre amp in more than one location.
Do you have someone to help you mount this on the Chimney? Straps are tricky to handle and you will need two people. May want to use four straps since the rotor and antenna will need to be secured well.
