Depending on where I mount the antenna the minimum distance from the trees would be 30-50 feet. That would be strapping to a fireplace (since I've seen this before I'm assuming it's no problem to do and is the easiest). If I mount the antenna differently the distance to the trees could be as much as 100 feet. I'm assuming by the question that distance is your friend when it comes to dealing with trees? I might be able to also trim the lower branches of the nearest trees to the height of the antenna if it will have a significant impact.
