Old 3-Aug-2014, 5:08 PM   #33
Ben Myers
KD3WB
Try pointing the antenna at one of the target stations and typing the real channel number into the remote. You may have to add a period or hyphen to tell the television or converter that you are trying to tune a digital channel. Don't be surprised if you see nothing on the screen at first, since many modern televisions don't show a picture unless a usable signal is present. If this doesn't work, see if you can find a signal strength utility in the menu. These sometimes allow you to select or step through the channels. Also, be advised that not all splitters will pass the DC voltage needed to power a preamp.
Ben Myers is offline   Reply With Quote
