Old 3-Aug-2014, 2:27 AM   #19
corvairbob
sounds like i'm in a fix. what i will do is point the antenna in the se and scan for channels and then move it to the ne and see if it will keep the channels i try to enter, there may be a place in the menu i missed i will get the book and double check and if i can't find any reference i will see if i can locate a proscan forum and ask them for help thanks.
what would be needed to make the cable headend to be able to point 2 antenna in different directions. is there a diagram on the site i can look at with parts listings.?
corvairbob is offline   Reply With Quote
