Old 3-Aug-2014, 1:10 AM   #17
Billiam
Originally Posted by corvairbob View Post
i was using one of those digital boxes only because i have a setup in the garage to test this and get it corrected. but i did try it on the proscan i have in the living room and that did the same thing. it would get the channels when i pointed it towards ne and when i moved it to the se the ne channels would go away and i had to search again.
Very odd. I have a Samsung TV and that will not usually lose a channel that I've scanned into it even after I rotate my antenna to another direction. If I rotate it back to the other direction and punch in that channel it will be there. Same thing with the Insignia Digital Box and Insignia TV that I own.
What digital box are you using? I have heard some TV's have this problem but not sure about digital boxes. You may unfortunately be using the wrong TV in that respect.
