Old 3-Aug-2014, 12:10 AM   #5
Denver , Colorado Springs , Both Directions are a Test of Reception.
The Signal Strength of Reception in Both Directions are Very Weak Signal
Strengths.
The Number 1 Concern is Avoiding Obstructions of Any Type or Kind in the Directions of Reception.
Recommend start with Test of receiving Denver stations first.
As to receive or not receive Real VHF high band channel 8 PBS in the direction of Colorado Springs.
That is your choice.
During the Testing Phase of reception you will have both antennas connected so aim both antennas at Colorado Springs Tv transmitters after the Denver Test of reception.
If during the Testing Phase , if Colorado Springs UHF Tv stations prove reliable reception.
After the Test of Colorado Springs Tv reception , then the 2 antennas can be turned back to the Denver Tv stations.
Then as a choice , you can install a -->Separate DB8e UHF Channels Antenna<-- aimed at Colorado Springs Tv Stations.
The Separate DB8e antenna -->Will Not Be Connected<-- to the Y10-7-13 antenna and DB8e antenna combination aimed at Denver.
If a Separate DB8e antenna is installed , then also install a , http://www.antennacraft.net.
10G201 preamplifier.
Remember the Denver Complete Antennas System.
Is/Are Not connected to the Colorado Springs Antenna system.
And even so , you may have to dice up the reception situation different ways , receiving some Tv stations from Denver and some Tv stations from Colorado Springs.
The Testing Phase will give you information of how the receptions and directions of reception will happen.
One example and not the only example is , the Y10-7-13 VHF antenna is aimed at Denver and DB8e UHF antenna would be aimed at Colorado Springs , and connected to a 10G221 preamplifier.
And their would be no Separate DB8e UHF antenna and 10G201 preamplifier.
Here are Tuners/Tuner Recorders that can be connected to provide reception in the directions of Denver and Colorado Springs.
http://www.epvision.com.
With Tuner/Tuner Recorders , a antenna rotator will not be required to receive Tv stations both directions.
This following information is Very Important.
The closer obstructions are in the directions of reception the more disrupted
reception will be.
The Tv signals are Very Weak Signal Strength so reducing the signal
strengths with obstructions in the directions of reception is Not Good.
Avoid obstructions in the directions of reception.
The closer obstructions of all types and kinds are in the directions of
reception the more disrupted reception will be.
The further away obstructions are away from the antennas in the directions
of reception the better reception will be.
Last edited by teleview; 13-Aug-2014 at 4:17 AM. Reason: Clarify information and typos.
