Old 2-Aug-2014, 5:56 PM   #12
corvairbob
Originally Posted by Billiam View Post
Two antennas pointed in different directions coupled into an AB switch would do the trick. I do recommend buying better antennas though. Again, which channel on your report is the weakest channel that you wish to watch?
i tried using the a b switch but i got the same with the searches every time i moved the switch i had to do a search again. so i got a device that looks like a splitter but they said it would either split or couple the signal. it i put multiple antennas on it i got one output if i one antenna on it i could get multiple outputs.
corvairbob is offline   Reply With Quote
