The DB8e UHF antenna provides the flexibility to Aim 1 panel at the 156 degree
aim direction and the other panel at , WHAG-DT , Real Current UHF channel 26
at 320 degree magnetic compass aim direction.
Doing it this way will most likely get you all the Tv Stations/Channels you
require.
And has the advantage of only 1 coax down lead.
And if not , then another Dedicated DB8e antenna can be installed for reception
of WHAG.
So is good that you installed the extra coax runs.
And made ways to easliy install more coax runs.
