Update: Ended up running a single Cat 5e and two RG6 QS to each room for data/tv in addition to smurf tubing to each room for future wiring. Installed an electrical outlet in the attic as well as conduit running from attic to the basement in two locations. Awaiting final inspection.
I have half of the RG6 and all of the Cat 5e home runs in the basement and the other half of RG6 home runs in the attic. Using RG6 DS from antenna/pre-amp to splitter in the attic. Mast will be grounded to 8' CCS rod using 6 AWG copper and clamps listed for direct burial. Grounding rod is bonded to the neutral-ground bus at the main breaker panel with 6 AWG copper.
The wife isn't crazy about it but I'm getting ready to pull the trigger on the Winegard HD7698 and RCA TVPRAMP and point at 156 degrees. I'm holding off on the rotor for now but would like to tune WHAG-DT also. Would a fixed, dual antenna setup work for this? Any suggestions on a separate antenna for that station in my area (2EDGE) to combine with the HD7698?
