Okay, I finally looked at your approximate location by working backwards from your plot which should put you very close to 40.403793,-111.931664
You're on the back side of a slope that's 1200' up to the peaks and the signals are mostly going over your head, Only very, very faint signals will actually make it down to rooftop level, if they make it at all.
The best you can do is get the antenna up as high as possible, tilt it back so it's bore-sited on the visible horizon in the direction of Farnsworth Peak, and then cross your fingers.
