The Tvfool radar report and channel list says , Only Resolved Approximately.
Please make and post a tvfool report and channel list that is the Exact address.
And make the antenna height in the report 25 feet above ground.
25 feet antenna height above ground is a reference antenna height that
provides a good evaluation of the Tv stations that are receivable.
If the the Exact address does not work to make the report then go the tvfool
Home Page and click on , >>Start MAPS<< , enter a zip code and move the
pointer to the Exact Location of reception.
Make the antenna height 25 feet above ground.
Make and post the tvfool report.
Do not delete the first tvfool report that says Only Resolved Approximately.
If the the new tvfool report shows about the same reception of
Tv stations/channels.
Then
-->Many<-- Digital Broadcast Tv Stations/Channels will be received with a
antenna installed above the peak of the roof.
