I knew somewhere I had a question/post for which I had not posted the answer I finally used.
Because I have two transmission locations at almost exactly 90-degrees - and am within 11 miles of the farthest, I ended up using a "directional" antenna (Solid Signal HDB8X), which allowed me to aim half of the antenna toward one location and the second half at the other location. The amount of signal I need at these distances is more-than-met by the antenna in this configuration. I was very surprised how simple the solution was. I certainly didn't think this arrangement was possible, and would never have come up with it without the help of a tech support person at Solid Signal.
