There are no VHF stations in Salt Lake City, so that eliminates all the combo antennas. Our DB8, DB8e, or 91XG would be my usual recommendations.
Antennas direct PA-18 as a preamp for the signal, but I could 't get it work
It should have worked fine except it looks like you're in a very strong FM signal zone. A simple $4-5 FM filter or two between the antenna and the amp should fix it. If you still have the amp on hand, run down to Radio Shack and purchase two of them and a a couple of short jumpers.
The other very, very common problem is when using coax re-purposed from cable or satellite installs. DC-blocking splitters or incompatible satellite multi-switches are the usual problems in those cases.
