Old 1-Aug-2014, 12:08 AM   #8
Here is 10 foot tripod antenna mount , to install above the roof.
http://www.ronard.com/712.html.
Roanrd (712-50-10)
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , a low price of about 12 dollars.
To collect more signal install a Antennas Direct DB8e UHF antenna.
http://www.amazon.com.
Aim the DB8e UHF antenna at about , 309 degree magnetic compass direction.
Use a real and actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
If 1 Tv is connected use No splitter.
If 2 Tv's are connected use a , Holland Electronics , HFS-2D , 2 way splitter.
If 3 Tv's are connected use a , Holland Electronics , HFS-3D , 3 way splitter.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
For all coax that is installed outside , use RG-6 coax that has the , Compression type connectors on the ends of the coax.
Not the old style crimp type connectors.
Reason , keeps water out of connections and coax.
