Old 14-Dec-2010, 11:56 AM   #3
wfagan59
Many Thanks
GroundUrMast, thank you very much for looking at my post. When I went to take the flat, indoor antenna back, they had a VHF/UHF Roof/attic mount antenna there, so I switched, bought some RG6 and tried it out. Works great. I now get in HD NBC, CBS, ABC, Fox, PBS along with the CW and other broadcasts from these stations in SD. UHF 15 did not come it, but that is fine with me. I'm sure a preamp would indeed help with this. I just mounted it on the same mast as my Dish is currently attached, which will be coming down on Jan 2 when my billing cycle ends. Also, from your name I think I already know this answer, my mast nor my cable is grounded. This seems to be a must when installing an antenna. Is it just to safeguard against lightning, or does it also help with signal noise? My stations are clear as a bell and look great or better side by side than the Directv.
Once again, thank you and I'm glad I have this forum to fall back on if I need some help in the future.
wfagan59 is offline   Reply With Quote
