Old 31-Jul-2014, 1:43 AM   #11
If MyNetwork and The CW are not being received and will like to receive them.
XHDTV-DT , Real UHF channel 47 , http://www.mynetworktv.com.
XETV-DT , Real UHF channel 23 , http://www.cwtv.com.
Install a , Antennas Direct , DB8e , UHF antenna . The DB2 will not be installed.
The DB8e antenna is installed <-->Above the Peak of the Roof<--> in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South East , South , East North East.
The Y5-7-13 antenna will be installed on the same antenna mast as the DB8e antenna , the Y5-7-13 antenna will be about 3 feet below the DB8e antenna on the same antenna mast pipe.
The DB8e will be aimed at about 150 degree magnetic compass direction.
The Y5-7-13 antenna will be aimed at about 209 degree magnetic compass direction.
Do not use the UVSJ.
In place of the UVSJ install a ,
http://www.antennacraft.net.
10G221 preamplifier.
Connect the DB8e UHF antenna to the UHF connection of the 10G221 preamp.
Connect the Y5-7-13 VHF high band antenna to the VHF connection of the 10G221 preamp.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
MyNetwork and The CW , are weak signal strength.
The antennas will need to be higher then about 15 feet above ground.
To that end , here are some and not all Above the Peak of the Roof antenna mounts.
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about about 12 dollars.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
As always , antenna aim can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Here is the , Federal Antenna Law , that says Yes can install Tv Antennas up to 12 feet above the roof , of Any Size so as to have Reliable Reception.
The point is , Reliable Reception.
Because Reliable Reception is the Main Point of Installing Tv Antennas.
http://www.fcc.gov/mb/facts/otard.html.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof and building in the directions of reception.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including the roof and building that the antennas are installed.
The directions of reception are , South East , South , South , South West , East North East.
Because of continuing reports here at tvfool of question askers that are having reception problems with the 2 VHF high band Tv Stations.
At your reception location are at 209 degree magnetic compass direction.
KFMB Real VHF high band channel 8.
KGTV Real VHF high band channel 10.
I do not recommend the smaller Y10-5-13 antenna.
I recommend the larger for better reception , Y10-7-13 antenna.
