Woos
Thanks for the quick reply. If WLOS is going to build the new transmitter what would the 250 Watt do to the variables in the report? Our guess was we were not receiving WLOS because the signal strength was weak. The variable that we focused in on the report was the NM(db) was at 13.2. So what would the 250 Watt transmitter do to our NM value? Or if our assumption was incorrect with the NM variable what should we focus on if/when the Watts are increased?
Again Thanks for the help
Reason: Correct a sentence
