Thank you for your reply tomfoolery.
1. No wire mesh in the clay tiles.
2. Joined with UVSJ connector. But the UHF side is open for now until I receive the 100' cable to join the DB-2.
3. The Y5-7-13 is about 4.5 feet off the roof at the mount point.
4. I will try raising or lowering but moving to another location is not a very good option.
5. How much would you suggest raising or lowering the antenna? 6", 1 foot, 2 feet, or?
Any other ideas? I thought both channel signals would be the same.
Thank you.
Daniel
Reason: More precise.
