Old 30-Jul-2014, 6:43 PM   #8
SDkid1
Need your advice
I installed the DB-2 in the front of the home and it works perfectly.
I installed the yagi Y5-7-13 in the rear of the home where the old dish was.
Used an under eave mount from Eave Mount dot com. $30 delivered.
The problem is with the Y5-7-13. I can receive Ch 8 with 3-4 bars of signal per TV. But Ch 10 I get only 1-0 bars and not usable.
It is aimed at 209 degrees magnetic. Both channels transmit at about the same power and from the same location.
Any idea what is happening with Ch 10 low signal?
Thank you.
Daniel
SDkid1 is offline   Reply With Quote
