Old 30-Jul-2014, 7:10 AM   #2
For the Reception of Tv Transmissions.
-->As Always<-->Attics and the Inside of Buildings Are Not a Reception Friendly Environment , and Never Will Be a Reception Friendly Environment.
For reception of the Strong Signal Strength Local Digital Broadcast Tv Stations/Channels.
Yes start with a , http://www.antennacraft.net.
HBU33 antenna , in the attic , aimed at about 40 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
A , http://www.antennacraft.net.
UAM9000 , J pipe type antenna mount will work Ok in the attic.
A antenna amplifier will most likely not be required.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
If reception situations happen in the attic that are not resolvable with antenna aim adjustments and antenna location adjustments in the attic.
Then move the HBU33 antenna to above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof and building in the directions of reception.
The directions of reception at your location are , East , North East , North , South South East.
The HBU33 antenna above the roof can be aimed at about 40 degree magnetic compass for reception of the local strong signal strength Tv stations.
As a Test of reception for more Tv stations channels , with the HBU33 antenna above the peak of the roof.
Can aim the HBU33 antenna at about 180 degree magnetic compass direction to receive weaker signal strength Tv stations to the South South East.
And the stronger signal strength local Tv stations will be received at back angles and back of the HBU33 antenna.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the HBU33 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
