Old 29-Jul-2014, 10:07 PM   #21
Then I will reword it.
Some or all of the componets can be bad.
Trees and tree leaves , plants and plant leaves , are Not Kind or Nice to Tv signals.
The closer , trees and tree leaves , plants and plant leaves , are to the antenna , the signal path , the direction of reception , to the antenna the more disrupted the reception will be.
The more distance , trees and tree leaves , plants and plant leaves , are away from the antenna in the direction/s of reception , the better the reception will be.
Moving the antenna up and down to find a better location for reception ,
Changing the antenna location to a better location for reception ,
and changing aim direction can all help with reception.
Can also install a , http://www.antennacraft.net .
Y10-7-13 VHF high band antenna.
VHF channels 7 thru 13 high band antenna for reception of.
WBRE-DT , VHF high band channel 11 , NBC.
WYOU-DT , VHF high band channel 13 , CBS.
Aim the , Y10-7-13 antenna at about 267 degree magnetic compass direction.
Antennas Direct sells a , UHF / VHF Antennas Combiner that is used to combine the ,
DB8e UHF antenna and the Y10-7-13 VHF antenna to one 1 coax that goes to the Tv.
Connect the DB8e UHF antenna to the UHF connection of the combiner.
Connect the Y10-7-13 VHF antenna to the VHF connection of combiner.
The remaining connection of the combiner goes to the Tv.
The Y10-7-13 antenna is installed about 3 feet below the DB8e antenna on the same antenna mast/pipe.
Can also Test reception , without and with a preamplifier.
Use a , http://www.antennacraft.net.
10G201 preamplifier.
The preamp can be connected to the remaining connection of the combiner that goes to the Tv.
