Realistically, all you need is UHF.
I would suggest an Antennas Direct DB8e
Aim one panel at about magnetic 250 degrees & the other at about magnetic 315 degrees.
You should pick up all the major networks & some of the outliers. Probbably the 2 at 70 degrees off the back.
Obviously trees, bulidings & other minutae could affect things, but that's where I would start.
Other, more experienced members may also offer other options
