Old 29-Jul-2014, 1:37 AM   #7
If the tvfool report is correct.
Then the location is a Simple reception situation.
No antenna rotator required.
Above the Peak of the Roof install a , Antennas Direct , DB8e , Current UHF channels 14 thru 51 antenna.
http://www.amazon.com.
Aim 1 panel at about 275 degree magnetic compass direction.
Aim the other panel at about 65 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
As always the antennas aim can be adjusted for best reception.
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter .
Also on the same antenna mast/pipe install a ,
http://www.antennacraft.net.
Y10-7-13 VHF high band channels 7 thru 13 antenna , about 3 feet below the DB8e antenna on the same antenna mast/pipe.
Aim the Y10-7-13 antenna at about , 41 degree magnetic compass direction.
Install a ,
10G221 preamp.
Connect the DB8e UHF antenna to the UHF connection of the 10G221 preamp.
Connect the Y10-7-13 VHF antenna to the VHF connection of the 10G221 preamp.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at ,
http://www.hollandelectronics.com
or
http://www.ronard.com.
Home Depot has 10 foot - 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the cost is low at about 12 dollars.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception are , South West , West , North West , East , North East.
