Thread: Best Approach
Old 28-Jul-2014, 8:24 AM   #2
A Simple reception situation.
For reception of USA and Canada Broadcast Tv Stations/Channels.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South East , South.
Install a ,
http://www.antennacraft.net.
HBU44 antenna , aimed at about 150 degree magnetic compass direction.
Here is how to aim antennas ,
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet and etc. compass.
As always , antenna aim can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a ,
10G201 preamplifier.
For 3 Tv's connected use a , Holland electronics , HFS-3D , 3 way splitter.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
http://www.hollandelectronics.com.
Here are some and not all above the roof antenna mounts.
Here are some places to buy antennas and etc.
http://www.saveandreplay.com.
http://www.trentondistributors.com
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative
Effect on Broadcast Tv Reception and so do buildings and other obstructions
including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the HBU44 antenna at a
location that has the least amount to no amount of obstructions of any type or
kind in the directions of reception including your own roof and building.
Last edited by teleview; 29-Jul-2014 at 7:14 AM. Reason: Clarify information and typos.
