Old 28-Jul-2014, 1:46 AM   #7
StephanieS
No problem, that's what we're here for.
When you mention 4 bay bowtie is it this design?
Or this?
Without a make and model number of the antenna, I'm not 100% sure which antenna you are running.
I'm reluctant to suggest any antenna changes at this point. If you are running a U4000 or similiar (the first picture) and you have favorable improvement on elevation a DB8e might be something to discuss as it is one of the best weak signal UHF specific antennas on the market.
The only other thing you *might* add would be a VHF beam in the Antennacraft Y10713. This would be dedicated to attempt reception of WWCP real channel 8 for FOX network service.
If this is something you chose to do, the RCA Preamp would come in handy as it has dedicated UHF and VHF inputs. Your Winegard has only a single input design.
Again though, were into "just do it," lol. We're outside of the normal TV fool map parameters due to being on a hill and doing these tweaks will give you a good idea if its a venture you want to put more money into.
Cheers.
