Old 27-Jul-2014, 9:25 PM   #5
StephanieS
Thanks for the added information. It appears there is some benefit around 100 feet, but not a great deal.
The best I can suggest is raise the antenna that additional 15 ft. and play with the aiming of Erie (magnetic 329) and Johnstown (magnetic around 150) and see what you get. You could purchase and test a RCA TVPRAMP1R to see if this aides.
If you see WJET that's a good sign. This map may be a bit more negative than your reception reality.
Sometimes we have to suggest "just do it" and see what you get. This is one of those cases. You have a hill to work off of and you experience better than predicted results already.
There may be an option for FOX if you get the majority of affiliates, but no FOX.
Let us know how it goes.
Cheers.
