Old 26-Jul-2014, 9:13 PM   #12
Jake V
Question
How did you point your antenna (inside and outside)?
Did you use a compass and aim to 344 degrees (roughly NNW)?
CBS (WYOU) and NBC (WBRE) at the translators at 344 degrees are both UHF (Real Channels 25 and 28).
If you were aimed at 267 degrees (slightly north of west) then CBS and NBC are on Real Channels 11 and 13, respectively.
The DB8e should pick up CBS and NBC if aimed to 344 degrees since they are UHF, but it would not be surprising that it might not pick up these channels at 267 since they are VHF (the DB8e will pick up strong signals on the upper VHF channels but it isn't designed to).
