i used the rubber and metal washer that come on metal roofing screws on old yagi i had here and 3 years later when i had to change the balun it was still clean and nice.the other trick is an aerosol that autozone sells to coat battery terminals in diesels to keep them from corroding.it seems almost like a clear coat.solder is prob best but aluminum is a pain i brazed on but it didnt hold.my micro butane torch works great for soldering with a good resin core solder.
