Originally Posted by ADTech
A zip-code level plot is usually close to useless since terrain and conditions across that area may vary significantly.
Please use the instructions in the sticky about the "reliable method" to generate a new plot if you need further analysis.
ADTech, thank you for the pointer to the sticky.
Ok, this is exact.
http://www.tvfool.com/?option=com_wr...e1c6ec1d44321f
The plot looks considerable different now, it really changes everything. My actual antenna height is like 10 feet, lots of trees around.
Looks like if I point the antenna to the west, I ought to have a better selection.
