Old 23-Jul-2014, 10:20 AM   #5
Install a , Antennas Direct , CS5 , C5 , antenna above the roof aimed at about 87 degree magnetic compass direction.
http://www.amazon.com.
Here is how to am antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Use a Real and Actual magnetic compass the aim antenna , do not trust a , cell phone , tablet and etc. , compass.
The C5 antenna receives the Current UHF channels 14 thru 51 , and VHF high band channels 7 thru 13.
The C5 comes with a , VHF/UHF combiner to add on a separate UHF antenna.
The combiner is not required for your reception location.
The C5 antenna Must Be Installed Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of , North East , East , South East.
If reception is weak signal strength , then install a , http://www.antennacraft.net.
10G201 preamplifier.
If the satellite system is active and the Tv antenna reception is being distributed by the satellite system coaxes , then I recommend connect All parts of the 10G201 preamp , Before Any satellite system components.
