Old 23-Jul-2014, 9:45 AM   #3
As a start.
Install a , http://www.antennacraft.net.
HBU33 antenna in the attic , aimed at about 150 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet and etc. compass.
For 1 or 2 Tv's connected a antenna system amplifier will most likely not be required.
If reception is weak signal strength on some Tv stations such as and not limited to , XHDTV-D , MyNetwork.
Then install a http://www.antennacraft.net.
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com
or
http://www.amazon.com.
If reception situations happen in the attic that are not resolvable with antenna aim and location adjustments in the attic.
Then move the HBU33 antenna and preamp unit to Above the Peak of the Roof in such a manner that reception is not , impeded , obstructed , blocked , by the , attic , roof , building , in the directions of , North East , East , South East , West North West.
Use the , ronard (911) , 5 foot tripod antenna mount.
Use the , ronard (4560) , eave antenna mount.
Measure around the chimney and use a , ronard (2212) , ronard (2218) , ronard (22240 .
Above the roof , aim the HBU33 antenna at 150 degree magnetic compass direction.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect , on Broadcast Tv Reception , and so do buildings and other obstructions including your own , attic , roof , building.
Some and not all , Negative Effects are.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building , in the directions of reception.
