Old 23-Jul-2014, 9:03 AM   #10
Here are some antenna mounts.
http://www.ronard.com/34424560.html
Use the , ronard (4560) , eave antenna mount.
Use the , ronard (911) , 5 foot tripod antenna mount.
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL chain link fence PIPE that makes good antenna mast pipe. The price is low at about 12 dollars.
Install a Antennas Direct , DB8e , UHF antenna . Current UHF Tv channels 14 thru 51.
http://www.amazon.com.
Aim 1 panel at about 150 degree magnetic compass direction.
Aim the other panel at about 200 degree magnetic compass direction.
Install a http://www.antennacraft.net.
Y10-7-13 VHF high band channels 7 thru 13 antenna , aimed at about , 213 degree magnetic compass direction.
10G221 preamplifier.
Connect the DB8e UHF antenna to the UHF connection of the 10G221 preamp.
Connect the Y10-7-13 VHf high band antenna to the VHF connection of the 10G221 preamp.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at .
http://www.hollandelectronics.com
or
