From your post I am assuming the Radio Shack antenna is indoors. After reviewing your TVF report I'm inclined to recommend an outdoor antenna. An antenna such as this http://www.solidsignal.com/pview.asp...0Antennas&sku= aimed at aprox. 60° on your compass should provide all the networks including PBS. This antenna is not designed to cover VHF 5 but WCYB (NBC) covers your area with their UHF 29 signal and given the high signal level of VHF 5, I expect that the antenna I suggest will deliver more than enough signal for you to see that RF channel reliably.
If you want to receive http://goodtimevirginia.com/TV/W43BO on UHF 15 you may need to add a preamp like this http://www.solidsignal.com/pview.asp...u=615798396145
Also if you are going to connect more than one receiver then you may find it necessary to use the preamp as well.
