Your challenge is a combination of stations in multiple directions and weak signals. To get everything that you want you will need either a rotator or several antennas ganged together. In your case you could snag Jointennas for channels 11 and 13 from the Channelmaster store, get a Y5-7-13 antenna for WZZM (ABC) plus a Y10-7-13 for WGVU (PBS) and a large channel 7-51 antenna (HBU-55, HD7698P, etc) aimed in the 200 degree range. The preamp you have is perfect.
The antennas will need to be at least 6' apart on one long mast and one short mast and aimed away from each other.
Reason: Typo on the Jointenna channels.
