Old 21-Jul-2014, 7:13 AM   #7
SDkid1
Thank you tomfoolery for your information.
Yes that is exactly where I'm headed.
The old sat dish j-pole is gone. And I have added 6" gutters to the 2x8 facia where it was mounted. And the facia is not exactly vertical. It is 90 degrees to the roof pitch.
My plan is to mount a beefy piece of 7x7 aluminum angle (about 10" wide) onto the facia.
That will be the foot for new j-pole in the SW corner to mount the Y5-7-13.
Then mount a DB2 at the front of the home. I have a place where I can somewhat hide it due to the small size. I found the DB2 is discontinued but still available refurbished.
I will have a long run from the DB2 to the SW corner Y5-7-13 and may need an amp.
Daniel
SDkid1 is offline   Reply With Quote
