Old 19-Jul-2014, 7:43 PM   #1
Albert101
Need advice on good attic attena to use
Hello,
Here's my report : http://www.tvfool.com/?option=com_wr...e1c6883204abae
I was thinking of using the following antenna inside my Attic :
FOCUS-8HD-90D : http://ca.focusantennas.com/focusantennas/focus-8hd_90d
I also have an CM-7777 booster installed inside my living room 20 feet away via an RG-6 Coax from the antenna (antenna in the attic) not next to the antenna like it should...
Currently I have an CM-4221HD in my attic pointed towards WCFE-DT (38) 57.1 PBS. I get most channels but some are not entering very well.
Will the FOCUS-8HD-90D + the CM-7777 booster work for me ?
I would ideally want all the channels circled in red if possible (excluding channel 8) (see attachement)
Thank you for your help.
Albert101 is offline   Reply With Quote
