Hello Mflanders,
Your reception plot requires you to mount outdoors either on the roof or tower. As ADtech gently put it, your hopes will be dashed by an attic antenna or roof mount through foliage.
If you really want to do over the air, getting above the trees is your only option with these weak signals. Anything else will just create frustration and lighter wallets.
You might want to create a TV fool plot at the elevation that gets above the trees. Then we can have a look and discuss from there.
As it stands, an attic install with these weak signals in a home surround by threes - don't bother easier to get the dish.
