The antenna would be aimed so that is points thru the roof material, it would be above the siding in the direction I would be aiming it. Does that make any difference?
Would you expect to get any better results if the antenna was on the roof? I am hesitant to spend several hundred dollars to have someone install it if the results will be spotty at best.
I also have a shed near the house that I could mount the antenna on myself but the shed roof is only about 8' high. I am completely new to the antenna world and know very little but it seems to me that height is very important and putting it on my shed roof wouldn't be very successful either.
