The seller of that antenna refuses to supply any technical specifications for his antennas, so knowledgeable persons have no basis for any recommendation and are skeptical about its design and capabilities.
Have you move the antenna yet? Your plot data suggests that signal should be relatively easy to capture but the antenna is simply in a "dead spot" for it.
