You will need a roof top antenna to get both those signals since they are fairly weak. You will also need a Rotor for the antenna since all the channels you have on the report are coming in from numerous directions.
If you are interested in WO2AG Ch. 2 or WCYB Ch. 5 you will need an all channel antenna like the Antennacraft HD 1850. If you don't need channels below Ch. 7 then the Antennacraft HBU 55 is your best antenna for this situation. You probably will not need a pre amp to get these signals at least not for the UHF signals. You might need a pre amp for Ch. 7 but I would first try the installation without one. If that does not work then check in back here to find out which one we can recommend. Hopefully there is still a VHF only pre amp being manufactured or available. You don't want a UHF pre amp because you have some pretty strong signals in Green and that will create interference issues.
