Old 18-Jul-2014, 5:00 AM   #3
SlingIA
Originally Posted by tonyp063 View Post
I've seen much worse reports.
You have a bunch of thranslators on the Jackson, MN tower at magnetic 20 degrees.
Rabbitears.info will give you the breakdown as to what networks they are
http://www.rabbitears.info/search.ph...ive+Television
Also see
http://www.ctv.coop/index.php?page=2
Scroll down to see the Jackson tower.
I would think that an Antennas Direct DB4E would serve you well. Aim it at about 30 degrees magnetic to start with.
https://www.antennasdirect.com/store...v-antenna.html
You can also add their hi-vhf add-on kit if cbs on 12 is spotty.
Other, wiser members may have different solutions.
Big thanks for the information! The CTV option is especially interesting since they have many channels available from their Jackson tower. However, they apparently charge $7 per month. That seems reasonable but how is it they can restrict someone from picking up the signals without subscribing? (Sorry if that's a dumb question but like I said, still learning about OTA services).
SlingIA is offline   Reply With Quote
